Any Post Bleeding Checks I Can Do?
jdp1under
ct
Hey Guys I Bled The System After Replacing My Left Side Heat Exchanger. I Blelive All Went Well I Followed Procedure And Dont Think There Is Any More Air In The System. What Can I Check Or Keep An Eye On Other Then Fluid Level To Make Sure I Dont Have Any Air In The System. I Have An 02 Viper With Rear Exchanger. Thanks
Ater running for 5 to 10 minutes make sure all heat exchangers are getting hot. If one is not getting very hot when the others are you still have air in the system.
Ya I Checked Upon Inital Start Up I Wathced And Waited For Thermosat To Open And They Got Warm One At A Time In Sequence And Them Were All Warm Equally. Thanks For The Tip
