just bought a used viper slp can, where is the spring on the back of the caN SUPPOSE YO GO? IS THERE A TAB IM MISSING, IF ANYONE HAS A PIC IT WOULD BE HELPFULL , THANKS
skidooboy
i think you drill a hole in a tab on the chain case for the one you are talking about. if the link works you'll be set, here it is http://www.startinglineproducts.com/instsheet/09-249.pdf
if that dont work goto www.startinglineproducts.com look under yamaha then exhaust then viper can look in right corner of page and there are install and tuning documents. ski
Thank You Ski
LoneViper
You drill a small hole in the support on the chain case and there is metal bracket bolted to it. The spring hooks to it.
I've got another can if you need it for a spare.
