GYT Jetting Guide
pogoyammie
Western Mass
Website
www.harrysautosales.com
I have a 96 V-Max 600XT that I just picked up at the side of the road. It's in pretty good shape, and looks to have been well maintianed. It seems to be running a little rich..ok, alot rich. It has a set of GYT Twin Pipes on it.
Does anyone have the jetting and clutching instructions for this set-up?
Here is the set up: 156.3 mains, std needle position, bend out the reed stoppers to 12 mm, set fuel levels to 25 mm. #50 pilots and Q8 nozzles.
Clutch: 8ab with 2.4g inner hole, 2.7g outer hole, p-p-p primary spring, 2 engagement shims, 50/41 helix, silver sec spring at 80 deg.
Thats the set up :D
