raised suspension
jordan
saskatchewan
do you guys know if you can put drop brackets on a srx skid without doin anything else like goin long travel etc.
i think its just the back one but hopefully some one can confirm that for us as well has anyone made ther own drop brackets i was thinkin of getting some fabbed up and if so how far cann you drop it safely witout affecting the functionality of the suspension
The drop brackets that I linked will drop the rear suspension either 2.5 or 3.5" depending on which hole you choose. The front mounting holes need to be also moved approximately 1.5 inches to keep the same shaft to shaft spacing. There is a few "how to" posts somewhere. Search drop brackets and it will get you there. You don't have to do anything to your suspension with these things. I have a set at my house, but am not going to install them until this summer.
Do you mean "Center" holes need to be moved? Fronts shouldn't need to be moved.
Yes, sorry. I mean the center holes are moved. The front stays the same.
