Help with a 97 700
kysledneck
Georgetown KY
Hello, quick story, Im live in Kentucky so dont say take it to the dealer! LOL! so we had minimal snow this morn but enough to run it through a flat field , checking plugs etc! hit the kill switch backed up the trailer DEAD SLED! this thing never doesent start! help with troublshooting please! also pulled the plugs cant see spark! SLED RAN PERFECT! Thank you! Dan
update
got it on the trailer, unloaded it disconected the harneses from throttle/killswitch pulled it 3 times started up reconnected the harneses still ran turned off wont restart! retried this 3 more times (discinnect etc) STATOR?
Yep, I would say it is the stator.You can check it with an ohmeter.Can't remember the specs for it right now now but try a search here for "Stator" and you should find a few threads with the specs.
Hey! I pmd you saw you had a issue before with this? I have all the manuals & tech updates, seems that a staror can kinda go out when it wants! I mean it just started after not for 30min, then it starts shut it off & dead again! its just got to be it! I guess new is the way to go?
