2001 srx 700 servo motor voltage
jdmt49
Minnesota
Update Err Flashing 07 Fixed!!
Does anybody know what voltage there should be to the servo??
how are you checking for the voltage? the servo will only get 12 volts to operate if idle is below 900 rpm or if the rpm's are above 7500. i think the 5 volts you are reading is the sensing circuit for the cdi ,its how the cdi knows what the servo is doing.
After checking other fixes for (temp light flashing 7 times) nothing seemed to work...even swapped the servo motor...after sleeping on it I came out this morning and unplugged the CDI and plugged back in and...did like a reset in the computer world of fixes and now everything is fine no flash code...servo seems to work fine it opens under 900 rpm and starts to pull at 6500 rpm...will go riding and see if it stays..thanks all for your ideas, Barry
