Carbides/wearbars for '03 MM
cappel
steamboat springs
Any suggestions on carbides/wearbars for my Max? Get some new stockers or...
Woodys Doolys or flat-top
Xcalibar
Stud Boy Deuce Bar or Shaper Bar
4"
6"
8"
60 degree
I mainly ride deep, dry powder but am looking for something that will handle well on the trail. Hold corners you know, no darting work well on sidehilling. Any help would be greatly appreciated.
doolys
I put on Doolys from Johnmaster and they take the twitching out on the trails . A definate must for the newer mountain skiis
how much play is in the front end? check your alignment, and put a small shim under the rear spindle so the front of the carbide is 1/8in higher than the rear, darting should be gone or close to it.
