polaris500
Ok i got a 95 vamx and while the clutch is out being rebuilt i figured id take the time to figure some things out and fix them while its in the garage.
Ok only way to kill this is with the kill switch. Turn the key off no affect.
Where should i start to look at this to fix this?
ground wire ? or mabe bad key switch ? just a guess
make sure the ignition plug is plugged in!
polaris500
Is plugged in. Only thing i noticed it did was kill the reverse alarm when not on. When on it works....
Ground seems to be connected but i decided to run it to a differnt place and still no go. Tomorrow i thinks im goign to get the switch off the part sled and put on it and see if it works or not.
