2000 SRX 700cc Throttle Position Sensor
MikeSr
Racine, Wisconsin
While I am waiting to locate a CDI box (part number8DN-85540-10-00 if anyone has one, with a 16 pin and an 8 pin connector), which looks like it could be the cause of my no spark situation, .....is there a way to test the throttle position sensor, other than disconnect the white relay?
The kill switch, ignition switch, stator, wiring harness, pick-up coil, all check out and still no spark to any of the three cylinders.
Stumped! Need help!
Anyone with a 2000 srx 700 live in the area of Racine/Kenosha/Milwuakee/Chicago where I could bring my CDI box over, plug it in to your sled and see if it is good or bad?
