mm skid in a srx
jordan
saskatchewan
is the mm skid an improvement over the srx skid ride wise i wanna go a little longer and i found a good deal on a mm skid also what would i have to change to make it fit
i got a 136 mm skid on my 01 srx with viper shocks and i really like it, the mounting bolts are all different though, i was lucky and got a mm tunnel, and the skid for 150.00, so i got the extension you need and knew where all the mounting holes were supose to be, i also went with 8 tooth drivers so i could run a 1 1/2 cut down paddle track. If you need pics and measurements let me know
Any late model skid is better than what your looking at...(DOO POO Cat). It will also be easier because they use 4 mounting points instead of 6.
