viper engine prob
00sxrjoe
Maine
Is it coman for the brass worm gear on the crank to strip? Friend of mine has had two motors do the same thing one stock with bolt ons other mod 780 with citty cat pistions and block spacer. With his bolt ons (hyper viper Kit)
just curious what this "hyper viper kit" is. also, i've never seen any of those brass gears strip. when he puts his cases back together, does he make sure the 2 gears (brass and steel), are interlooking correctly, before torqueing down the case? also, are the bearings that the water pump shaft ride on, like seized up or something?
