I have a 98 MM700. I bought it last year from a guy who liked to mess with the carbs. The elevation in our area is around 1400ft. When I trail ride I can run about 100 miles and the plugs will start to foul. The center carb and the clutch side carb are the ones that give me problems. The exhaust side always runs good and has a good burn on it. I want to drop the needles to lean it out a little. I bought a repair manual from Clymer, but it doesn't go into detail on how to do it. Can it be done with the carbs in the sled? how far should I drop them? How do you get them out? Any help would be greatly appreciated. Thanks.
