I was wondering if you could put 9th drivers on a Phazer?
Mysledblows
I suppose you could, but without a drop and roll you are not going to get much of a track in there. 1.25 is tight with 8's. I've got a set of 9's off a srx that I'd give you if you want to try it. Just the drivers, no shaft.
Thanks Ryan, I'm heading to the UP on Friday so I've got my 7tooth with a 2" on it now. I was just thinking for around here I dont need anymore track than a 3/4. Just want to get a little more speed.....
and i have a phazer drive shaft you can have, jus the shaft. for a quick change out....
15 spline big-kid?
..SNAKEBIT..
got a 1992 Phazer for my son and looking to install a 136x1-1/2 will this fit with the stock drivers? what is stock 8's? can a guy find used 7's if I need them????
Mysledblows
8's stock and a 1.5 is going to be really tight. I'm not sure it will fit. 1.25 is a bear putting back together, but works great once it's in there.
you will need 7 tooth drivers
yamahaphazerst
..SNAKEBIT.. said:got a 1992 Phazer for my son and looking to install a 136x1-1/2 will this fit with the stock drivers? what is stock 8's? can a guy find used 7's if I need them????
You want to put a 136 track on? or do u have one on already? i got a 1992 yamaha phazer to. im going 136 and you need to put rail extention on.
