1991 phazer fuel jetting
mmdtraveler
Defiance
I have a 91 phazer II 480 and recently picked up a Bender Racing Pipe for it since I Blew-out a hole in my stock exhaust. I called Bender for jetting info but they no longer have the spec sheets on this machine. I live in NW ohio where it never really gets below 10 degrees and we have 10% ethonol in our fuel. Does anyone know what size jetts I should run? It sure would beat buying 10 sizes over any working my way down till I find the right one.
i know you lean for ethanol cause i work there but your sled should be stock tuned for right around that temp and alt. how your plugs look? if they are black and or wet you are rich. if you are rich try one clip up on the needle and one or two down on main jet like from 310 to 300 or 290
