I was riding my 2000 srx 700 down the trail and it was running fine all day then all of a sudden my lights started flickering and my gages quite working the sled didnt die but it would barely move and my head light was really dim. when i unpluged one of the bulbs the light got brighter again and some of the power came back to the sled but as soon as i pluged it back in the lights dimmed again and now power. i have looked throught the wiring for any shorts or melted wires and have checked all the glounds thinking that one may have come loose but found nothing. if anyone has any ideas i would really apreciate it.
wire harness under the engine is probably rubbed thru.. do a search on here easy way to fix, Common problem with SRX.
chilli
yep, rub through....sounds exactly like my symptoms I had, ground wire (brown) was 1/2 rubbed through
Any flashes??
Any flashes??
NYsledneck
Yup sure sounds like the dreaded rub through under the motor!
