YamahaSXR700
Hi i just put some new gaskets on my top end and i need some torque specs for my cylinder head could any one help me out here? thanks
Stef
Stef
mopar1rules
17 ft-lbs should do it....i checked tech section for ya.
YamahaSXR700
are you sure im pretty sure it was 27 lbs that why i jut post a forum to make sure but now u said 17 im pretty sure its that nowthanks!
What I do
I do 27 on Cylinder nuts and 18 on head bolts and or nuts. Have been known to go to 22 on red head bolts to eliminate leaking when gasket layers have been removed.
Not saying this is "by the book" it's just what I have been told and done in the past.
Madmatt
Madmatt
YamahaSXR700
yea the reason i have to change my gaskets the guy i bught the sxr off got TWO layers off the head gaskets so u have to run high octane gasoline have no choice I didnt know that so i ran regular and burnt my head gaskets and to much compression its the head are shaved so im geting new gasket keeping it stock but it does make a difference with compression and torque
YamahaSXR700
there IS a torque patern too right?
what year sxr?????
18 ft lbs.
18 ft lbs.
YamahaSXR700
thanks man i appreciate it
YamahaSXR700
but does it make a diference where i went ? i did 10, 12, 1, then 6,5,11, then 8,2,14 goes on... does it make a difference?
Ahhh you should have followed the pattern 1 then 2 then 3 then 4 and so on, why did you do it that way??? thats why there numberd
YamahaSXR700
but can i re do it? or its not good
srxbully
if it's already done..just leave it.
^^x2...just keep an eye on it for leaks,should be alright..
YamahaSXR700
alright thanks! i was to in a hurry i just got my gaskets today so i coiuldnt wait sorry
i know the feeling....lol
YamahaSXR700
lol i cant wait to get it started tomorrow i need my sparkys, im waiting on it missing my SXR
