Premix Ratio?
silversnow
Avon, NY
I need to run Premix in my 84 Phazer for a little bit. is 50-1 a decent ratio or should I go heaver?
Silver
all depends if the oil pump is still in operation or not as to what ratio to use. too much oil and you will foul plugs
well, that's the problem. I don think the pump is working. I need to premix to see what's not working.
