YamahaSXR700
k ive just received my new gaskets froim th mail and there cometic gasket should i put some ITAK spray on them before installing them, im just asking if its better or not because it says on my installation tips that dry installation is recomended! any idea should i put them dry just like that
Never used a cometic brand gaskets. Are the fiber or metal? Do they already have a coating?
YamahaSXR700
they are metal whatu mean coating there little black i guess it says in tips dry installation is recomended
srxbully
i never use any tack spray.just torque to specs & you should be fine.
YamahaSXR700
wha are the specs i got told 17 ft/lbs 18ft/lbs
srxbully
im not sure.dont reacall.if nobody here chimes in.call a yamaha dealer & he will be able to tell you.
