PNPerformance
replace head gasket's and check inlet needle and seat on carb's
PNPerformance
take a small drill punch and gently tap the pin. suport the pin tower if you can too get those needle's and seat's out and inspect them real good.may have too replace.with new one's
sledbuttrob
Update
Found a small leak in the PTO cylinder exhaust. Rub through from the other exhaust clamp at the muffler. The piece the spring hangs on to rubbed through. Moved the clamp, welded it up and runs fine. That would make the cylinder leak antifreeze and backfire????? OK that sled is fixed. Now I seize my other 700. Next post.
