Exciter belt width....?
Joatmon
Northern California
Hi folks, I believe my 88' exciter is supposed to run a 1-1/4" width belt. Well, I needed a new primary clutch and the one I got (Comet 108exp) is for a 1-3/8" width belt. Shouldn't I be able to shim the secondary clutch wider to accept a wider belt?
Any input would be most gladly appreciated!
Oh, I also received a silver/orange spring with that clutch...I think that might be for an 570 SX ...anybody know?
I'm not sure, but I think that you have to machine off .140 form the helix. Check with Reichard's Performance Center ifi they're still in business.
Good Luck.
Thanks!
Does anyone happen to know if the 87-89 exciters had a different secondary from the Exciter II's? The clutch table I was looking at show the later models running a 1-3/8 belt??
