Temp Sensor ????
jdp1under
ct
Hey Guys I Posted Earlier About Aftermarket Temp Gauges For The Viper. I Was Searching On The Web For Some More Info And Came Across A You Tube Video About How To Install One And I Watched It. This Guy Had An 02 Cat Zrt And He Used The Stock Sensor For His Idiot Light And Just Unpluged The Light And Used It To Feed The Gauge As The Temp Sensor. My Question Is We Have A Sensor In The Viper For The Idoit Light So Do You Guys Think If I Add A Wire That It Would Send The Temp To A Gauge. Im Thinking Of Adding A Lead On The Sensor And Not Disturbing The Idiot Light Set Up. What Do You Think????
i dont see how the sensor for the light would run a temp guage and be accurate ...you can drill the collant rail on the center cylinder and tap it to accept a digital guage ...or i read about splicing a metal tube into the collant line that has already been tapped for a guage .....i wouldnt mess with the orgional sensor ..
That Makes Sense To Me But I Thought It Was Interesting Because One The The Wires Has To Send Temp Info For The Dcs To Know If Its Getting Hot. I Dont Want To Drill Into The Head I Will Probably Go In To The Hose With A Fitting Before The Bottle.
