bigbigrichie
just got a new exhaust temp guage
what should be the max before burn down ?
the guage shows 9000 as red hmmmm
98srx6
9000°F? Sounds a little bit high to me...
I think somewhere in the ~1300°F area is when you need to start worrying about engine damage. This number can vary between engines, so Im not sure what temperature you should look for with your specific application.
Wilson
I wouldn't let it get over 1250 .
B2SO
- Aug 18, 2003
im with wilson , 1250 max ...not for sure but would think for trail sled 1200-1225 would be safe max ..also depends how far the probe is down the pipe away from cyl.
bigbigrichie
>>>>my brother says its in celcius instead of farenheight. does anyone know how to figure that out >>>>>sorry for the spellingbigbigrichie said:just got a new exhaust temp guage
what should be the max before burn down ?![]()
98srx6
C° = ( F° - 32) / 1.8
Thats not right either, if the temp were 9000°C, it would be over 16000°F.
At 9000 degree C that would melt a diamond!
bigbigrichie
go to find out its.... x100 so the red line starts at 900 deg c what is that in farenheight ? thought it was x 1000
acnas
bigbigrichie
1652 f. is 900 c. wow thats pretty hot
vipertripplexxx
Temp depends on how far away from the piston skirt you are. At 10" away you can run at 1400f all day long. At 6" away 1200f max. I would say probes 8"-9" away @ 1250f. Then take A plug reading to see whats up, and go from there. Let your plugs tell you what temp to run. m2c
bigbigrichie
The probe is going to be about 5" away in the y pipe
thanks for the info
LeT It SnOw
thanks for the info
LeT It SnOw
