viper frozen up
xviperx7
Wiscasset
i went to start my sled tonight it was parked at an angle on a hill tryed pulling it over started..... died.... put gas in the pistons started died.... ou get the picture looked in the tank and on the left side of the sled if you were driving it was an ice chunk assuming it had watr in the gas how do i fix was going on a trip tommorow and was hoping to get it fixed by then any help would be great thanks :2strokes: :o|
was the fuel pump update done ? just add a few washers under the pump. The bleed hole freeze's up on the 02's. It was a recall. Try warming it up with a hair dryer and see if it starts. Good Luck
tried a heat gun this morning 650 degrees of hot air and blew it at the fuel pump still it would start when putting gas in the pistons but quit as soon as it used up the gas in the pistons any help would be great guys i have a trip planned for tonight..... :o| :dunno:
Leave machine inside to completely thaw the ice which is in the tank. You need to completely drian all of the water from the tank, If you have enough that it freezes and you can see an ice chunk that is a fair amount.
i agree,,it needs a good thaw,,then if you don't want to drain things run some dry gas through it,that'll pull any water out..just don't over do it,and
get your gas somplace else...
Happened to me twice this year with summer gas i'm guessing. Put a hairdryer on pump then on carbs for 20 min and been good since.
