121 to151 kit
SUPERM
Avon MN
I just got done installing the 121 -151 hartman kit with skid relocate in my 97 700 sx It looks great but when I sat down on it , it hit the control rods and stopped dead. I pulled the shocks out and you cant move the suspension up after hitting the rods. I called Tom and he said this is how the system works. I am just afraid I will break or bend something. Has anyone ran this type of setup.
When you mounted in the rear upper mount you didn't have the rear sissor arm pulled forward and now the rods sit in the full couple position, will have to redrill your mounting position.
I found my problem. When I mounted the rear drop brackets I used 1 wrong guide hole. Works much better now. OOPS.
