SRX Jetting for Cold With Bender Can
jsutton83
gregory michigan
I'm going riding (SRX 2001) in some (what I consider )cold weather this weekend (-5 to 10 degrees). I have a bender can. I was told that some will go up a jet size with the bender can, because is tends to lean the sled a bit. My plugs look like an orange/brown color. They are the stock jets. My buddy has the same sled with the stock can. His plugs certainly look a bit darker. We have run them in the same conditions recently. Any thoughts? Thanks...
Stock jetting on a 2001 is on the rich side. Leave it there, and you will have no issues. I always ran less than stock jetting, and at temperatures up to -20 celcius. No issues. The bender can does not affect jetting.
jsutton83 said:
yea....leaner can also mean clank clank clank.......bog.......DAMNIT$$$!!!
i was trying to say leave it.the temps you mentioned are not that cold.you will be fine.
lol.. well i duno about the clank noise didnt hear it when mine went but x2 on the bog... n DAMMIT WTF $$$$
im actually gona change my jetting on my 00 srx to the 01 specs... was the reason my engine went to begin with... i think...
