EGT Iinstall by: ekimsx600
http://www.totallyamaha.com/snowmobiles/aaTECH/EGT/Pyro Pro 2001 EGT.htm
SRX REVERSE INSTALL SUPPLEMENT By srx_eh
http://www.totallyamaha.com/snowmobiles/aaTECH/Reverse/srxreverse install.htm
few more
M10 Jack Install:
http://www.totallyamaha.com/snowmobiles/aaTECH/Offsetaxel&Jack/fastjack.htm
8"Wheels and Offset Axel Install:
http://www.totallyamaha.com/snowmobiles/aaTECH/Offsetaxel&Jack/offsetshaft.htm
M10 Jack Install:
harpo
have a 2006 attak my reverse has been sticking making it not able to go into reverse is this common with close to freezing temps
Sounds like you need to adjust the reverse linkages. Lots of good info on how to do this on the 4stroke side
please post on TY4stroke.com
I am sure you need to clean the grease off the shifter that pulls out.
none of the links below for the new tech works for me. says not found.
staggs65
Don, they were new in 2004. Old thread dug up from the depths
All fixed
sorry didnt realize it was old, still just bee boppin around all this new stuff to see what all the changes are and happened to click on them and it said not found.
thanx for fixin it, will have to pay more attention to the dates i guess.
your doin a great job by the way!
Thank bud. Its ok if its old, Still needed to be fixed. Please let me know if you see anything else.
