Bender Roller Rooster Question
Mahoney
The nice part of Jersey
I want to change the degree setting on my roller rooster secondary but am unsure how the cover(helix holder) goes back on to get the right twist. I should have marked it first, but daaaaaa I didn't. I'm sure the top must line up with the bottom specifically to get it right. Does anyone know?
clutch
With the cap off look for your number settings stamped into the sheave. Insert one end of the spring into lets say position #1. Then put the roller cover over the other end of the spring ( top ). #6 would give you a setting of 70. Twist the cap clockwise the the next bolt position, push down and bolt up!
OK that's what I did. I just wasn't sure about the twist to next bolts clockwise part. I moved from 80 to 70 and when I hit the throttle hard from a coasting roll I think the belt is slipping real bad now. I have a 47/43 helix in it and a silver spring.
