Biggest Bottom gear possible?
dirtjumper895
Suffolk, VA
Howdy yall,
What is the biggest bottom gear that you can run in a 04 Viper Mountain chaincase. I am currently running 21-39 with a 70 link chain with 8 tooth exos. I would like to achieve a 2.25 ratio, so i think a 42 bottom gear would work mint. Anybody run a 43? Can we fit a 43?
Thanks!
Jeff :letitsnow
43 you might need to clearance your case a bit but it will fit....i run 21/42 with 8 tooth and am prolly going to a 20/43
NO!! you do not need to do any mods to the case. The only thing you need to watch is the tabs on the newer style gasket. This is why you run a 13w bottom gear. As well as saving weight/ rototing mass............SRXtreme
By running a 13w bottom gear wont the chain walk back and forth on the gear? Or does 13wide= 3/4"?
My hyvo chain is 3/4" wide
SRXtreme said:
Another note if your not running HYVO use a 15W top gear and a 13W lower gear..................SRXtreme
