Does any one have any expereince with there products??
Good? Bad??
I bought some wear bars from them and, lets say its not going well.
Waiting for a response from them...
Good? Bad??
horkn
The stud boy shaper bars are bar none (pun intended) the best runner set you can get.
They are seriously that good. If you want adually type, they make those too.
I wanted a set of dually's for my venture with 98 srx skis, since I absolutely love the 6" shapers bars I have on my 00 xcsp.
I was bummed that stud boy does not make shaper bars for the 98 SRX skis, although i hear you can just drill 1 more hole in th ski and the 00 srx wear bars will fit. Stud boy makes the dualys for the newer srx's.
chilli
I run 6" dually sharpers....retarted....
ViperXC
I have 6" shaper bars and so far I am liking them on my long track Viper.
horkn said:The stud boy shaper bars are bar none (pun intended) the best runner set you can get.
I bought both a 00 up set and a 98/99 set. 99 set just bolted in, the 00 and up set I just had to swap the bolt around with the one in the saddle.
No drilling new holes. The nuts included in the package were worthless however, stripped right out with out any force given to them. They sent me a new package with revised nuts, And then all went well.
horkn
I think I see what you are saying DV8. You simply take a saddle bolt off and make the newer set of carbides work that way? That is easy if that is the case.
right, I moved the saddle bolt to the back hole of the saddle and the wear bar goes in the original mount hole of the saddle bolt.
I have the 6" shapers on my viper and they rock. I have had the others and they seem to last longer and stay together (not missing carbide). I use Woody Megabits for the studs.
Call or email Rich from Rich motorsports he will hook you up.
Well if you don't hear from them you can always drive out to their office. It's only about 30 minutes down the road. BTW Brian did you see my message in trail conditions?
No I didnt see it, I will search..
Joe. Did you ride this weekend?
