Edge Skid in an 02 Viper, need some opinions please
YrkViper
York, PA
I am putting an edge skid into my 2002 viper.
It currently has the factory Proaction skid with rail extensions to 136" and obviously a 136" track.
I want to go to a 144" track on this puppy.
The edge skid is 121" so the way I looks at it I have a couple of options:
1) Go from 121" to 144" with rail extensions
2) Go from 121" to 141" with rail extensions and set the skid back 1-1/2"
3) Go from 121" to 136" with rail extensions and set the skid back 4"
What I don't know would be the pros and cons to #2 and #3.
Ideas?
I don't have any answer for you on the 144 questions but when you get around to selling off the 136 stuff, give me a shout.
I'd do the 121 to 136. While swapping the track go to a set of extrovert style drivers. Set of 8 inch wheels for the rear axle, and set the skid back about 2 - 2.5". This way you can run the track sloppy loose, eat up a little of the extra length with the bigger wheels, run a shorter extension, and not have to set the skid back so far as to screw up the ski pressure. My opinion anyway. Have fun with the project.
I have a polaris pro x 121 with rail extensions to 136. It is set back in the tunnel 4 inches, and rides just like it did at 136. Only difference is it get up ontop of the snow better. Maxdlx
Will do ;)! Hope to pull it out this week...
Thanks Ryan, would you also change the gearing or leave it as is.
Got a 144" 1.25" ripsaw going in with studs...
Perfect! Thanks Max good to know :2strokes:
