Im new and I need help
ViperFangs
Liberty,Ny
I have a 2002 Viper and it seems to me that it isn't getting any antifreeze to the motor, when I have the back end up in the air the overheating light doesn't come on, but if the sled is sitting normal it comes on after about 2 minutes and stays solid. And when it is sitting normal if I Squeeze the hose it goes out but I have to keep squeezing it. What could the problem be guys?
viper got problem with water pump ...... look in the search section they talk about it last year ...some issues with stripping impeller i think
It'll be one of three things.
1- Your thermostat is staying closed, which is looping all of the coolant only through the motor, and not through the heat exchangers so it is not cooling.
2- Water Pump
3- Water Temperature Sensor is faulty (but it usually throws a code, which flashes 8 times, repeatedly)
