#$%#% recoil starter spring helllllp
i dont't know of any real trick,but a second set of hands makes it a hole lot easier.MAKE SURE you install in the correct direction because it really sucks to have to remove it again after finally geting it in there.
i recently had mine out,not intentionally i might add and i couldn't get it by myself. Got my buddy to come over and it was much easier. I found the best way was to start in the starter cup housing,then as you feed it around get your buddy to hold it to keep it from coming out. once you make a coulple of wraps it gets easier to hold. make sure you keep it down flush with the lip as you wrap. hopes this helps!
