Sno_Racer_Xtreme
tomarrow there are some local 1000' radar runs and i was wondering what gearing i should be running. Right now i am running 23 top and 38 bottom. Also, what should i be running for rpm's with trail ported cylinders?
Sno_Racer
Sno_Racer
Undertaker13
Where In Maine?
Sno_Racer_Xtreme
portage lake, bare ice.
Undertaker13
Where Is That?
Sno_Racer_Xtreme
near ashland
Sno_Racer_Xtreme
anybody with a gearing suggestion?? or what my rpm's should be?? radar running tomarrow morning, lol.
PNPerformance
ARE you running stock clutching on both primary and secondary.
9801srx
most trail port jobs run at 8500 same as stock.gearing ,stock like you have (if you are light )or a 39 or 40 on the bottom if you are heavyer.
Sno_Racer_Xtreme
right now i am running right around 8500-8700 bouncing around in there, does this sound right??
so how did u do on your run
Sno_Racer_Xtreme
ended up doing pretty good, slower than normal but the track was in bad shape. Had some ridges and about 1.5 inches of snow everywhere, and was snowing like a blizzard, also a scortching -20 degrees. We were running 97 which was enough to get a first place, two second places, and one third place. Everyone i knew there was getting a lot slower numbers than normal.modsrx said:so how did u do on your run
Triple X
Sno_Racer_Xtreme said:right now i am running right around 8500-8700 bouncing around in there, does this sound right??
Top end rpm should be no higher than 8500rpm, the ignition starts to retard at 8600. Anything over the 8500 and you start to lose hp.
