BlAdE
What Should The Compression Be On A 03 Viper Mountain?
I Was Told I Had 110, 110, 115 They Said It Was Fine But I Think Thats Quite Low And Should Do Something Before Everything Goes Bad, The Sled Runs Fine But I Dont Want To Chance It
Viper-Rules!
Those numbers sound okay. The Mag side is always lower, since they stepped down compression to have uniform jetting. Every guage is different so all that matters is that you have over 100 psi and they are uniform readings, except for the mag side, which should be aboyt 5-8 psi lower then the rest.
BlAdE
ok thanks, i was a little scared to drive it like that but i guess it looks like ill be rideing tomorrow
