Bent front end
archer
Brighton MI
I dont ask for help very often (any more, at least) but I need some now. I hit a rock in the road with the 2002 sxr600. I didnt notice at first but it didnt take long till I saw the front left ski pointing in a lot farther than it was before. I looked it over and found the bolt that connects the ski (C&A Pro) to the spindle was bent and the wear bar tweaked right under the the spindle. I got a new bolt and straightened the bar and when I put it back together it was still toe-in by 1.5 inches as measured to the track and right ski. I dont see anything else bent. I took some pics. Anyone see anything else?
Are you sure nothing else is bent, even the tunnel alittle where the trailing arm mounts to it? Cause to me the a-arms look like they are forced foward in the bulkhead mounts, and forced backward at the trailing arm. Nothin looks bent, maybe tweeked though. It doenst take much to through ski alignment off in any sled. Aluminum moves easy.
The spindle
The splines look OK but is it supposed to bent? I dont think so. Max, I really hope I dont find the same effect in the frame or bulkhead. I guess I can just "adjust it out" if I have to. Maybe.
What about the tie rods inside the sled under the hood. Both time I bent tie rods it was the inner part that bent. Maxdlx
Def a prob with this picture... The spindle is supposed to be stright and not bowed like it shows. I think one you replace the spindle you will find that your alignment will be much closer to what it was. T
Bent Spindle...the Left Shock Kinda Looks Bent In That Picutre, But Cant Tell If It Is Just Distorted Or Actually Bent.
How big of rock did you hit, both spindles are toast. Did you happen to check the suspension? I hit a rock last week and sheared off one of my front heat exchanger protectors.
The pics are of the left spindle only. I turned it over for a shot of the other side. The shock does look a little bent in the pic but its not. I am not sure about what I hit but I dont remember anything that I thought was that serious. Its my wifes sled so now she's angry. I am having knee surgery next week that puts me out for the rest of the year so this weekend is our one and only trip. I have to get it fixed by then or I am in deep trouble.
Check the specs on the front syuspension on the right sde and see if the numbers are off. That will tell you if your trailing arm or anything else is actually bent.
