Hey fellow viper riders out there. You might want to keep track of your oil and gas consumption to set the oil injector pump cable. I know this has been discussed before on this forum, but i was shocked when mine had been set to yamaha specs and my motor was actually running at about 75:1!! I think low oil consumption is the root of most viper engine problems.
Millinocket Rocket
yamirules said:Hey fellow viper riders out there. You might want to keep track of your oil and gas consumption to set the oil injector pump cable. I know this has been discussed before on this forum, but i was shocked when mine had been set to yamaha specs and my motor was actually running at about 75:1!! I think low oil consumption is the root of most viper engine problems.
Yeah, mine was the same way. I adjusted the cable back to specs. The gap is supposed to be between 19.5 and 21.5mm, and mine was at 23.5(lean), so I put it to 20.5.
