Helix change
reedb
new york
How difficult is it to change the Helix. I have a Bender unit I want to put on, is it a shop job or can I do it at home.
You can do it yourself at home. Take the complete secondary off the sled and work on it at a bench/table. Pull the nuts off the tower and it comes apart pretty easily(careful as there is some spring pressure on it). Put it back together with the spring ends in the right holes. It is easier to get together if you hold the clutch together and have someone else start the nuts for you.
