stopper band adjustment(suspension) on non XT vmax
yankeeslover
ny
hello... 96 vmax dx version...I was looking thru a svc manual lastnight, and in the manual it says that you can change the settings on the stopper band on the front and the rear in the rear suspension, i want to put more weight towards the skis....It looks pretty easy to do, but the one thing thats confusing me, is what bolt do I remove? the top bolt or the bottom bolt? this is on the stopper band, each one has two bolts, the manual does not say which to remove the top or bottom, and is it the same for both the front stopper as the rear stopper? thank you, Pete
