BlAdE
hello, my sled is leaking coolant on the left side right where the rear part of the suspension bolts on, looks like it comming from the left rad but i cant sceem to find the leak can anyone help?
i am putting on an aftermarket can and i dont know the brand, should i re-jet? if so what size should i go with, im also putting reed spacers on it same time,
my speedo dont work but everything else works fine, what should i look for? sometimes my lights quit and i have to shut it down and fire it back up to make it work again
i have a hesitation problem when i just pin it from a dead stock, bogs then cuts in, and i have to give it a bit of fuel when starting it when warm
what are the best plugs to run in my sled?
thanks in advance any help would be great
