Undertaker13
My Boss His Srx Blew Up Again. The Oil Line Keeps Coming Off And Takes His Engine Out! This Has Happened Twice! Is This Common Or Something Out Of The Blue? Thanks Any Help On This Subject Would Be Great!
Oil line coming off where??? the pump?
I secure every thing under the hood, All the vibration and bumps it takes, Use clamps or zip ties on every hose/line.. That way you dont have to worry.
Undertaker13
yes sorry the pump!
I had it happen a long time ago, when I first got into snowmobiles, burne dup a engine, after that,,, replace any line thats hard or cracked, and secure each end..
which one is coming off, inlet or outlet line?
Undertaker13
I don't know which line? I'll have to ask him
That is very odd the clamps used on that stuff is usually very tight fitting obviously, it pretty important,new one to me.
it could be weak holding clips, hard brittle lines.was thinking there is a 1 way check valve . on backwards maybe?
good thinking ram,could happen,with them OWV's..ramblnman said:was thinking there is a 1 way check valve . on backwards maybe?
