Oil Cable Adjustment Question?
jdp1under
ct
Hey Guys I Have A Manual And Searched The Post For Some Info On This Adjustment. My Question Is When You Measure The Gap Do You Have To Pull The Cable Out Of The Adjuster? If So Do You Measure It As If Its A Wide Open Thottle? Mine Is Sitting In The Adjuster When I Pull The Cover Off So Im A Little Confused.
Kinda What I Thought Because If You Pull It Out Of The Adjuster Like The Pic Shows I Know Your Pulling On The Pump Arm. I Really Appreciate The Help. Conformation Of What Your Thinking Allways Helps...
