viperdougc
I have put new seals on my crank and realized that I have to line up the litte "nubs" on the bearings into the holes on the lower crank case.......this is EZ when building the motor from the bottom up but are there any tricks to making this easier when all I have is the base removed.
Any help here would be great
ottawaair
the little nubs all go to one side, there is notches in the case half for them. they do not go in the little holes in the bottom of the case.
2strokinit
Help
You want some yammie pdf help??
Vector88
the dowel pins on the bearings does in the slots on the top part of the case right where the 2 cases go together. cant get much easier then it already is.
viperdougc
thanks guys just wanted to make sure...the manual I have only show how the two bearings on the end line up...all done and torqued
