red rider
Does anybody know if you can use an SRX crankcase and crankshaft with a viper top end in a viper chassis?
9801srx
yup,as long as it's 2000 and up.
red rider
A 2000 or newer because of the 3D ignition?
Yes
More specifically, the pick up trigger is mounted in a different location in the 98 and 99 cases. When they went to the hotter ignition the diameter of the flywheel got larger and they moved the pick up mount. The location can be modified in a 98 or 99 case but not without some knowledge and tig welding. The 2000-2002 SRX's used the same basic electrical system as the Viper.
Madmatt
Madmatt
and the case part# are the same. looked it up for brother kirkswim because his is cracked.
