Scooter6901
Hi Guys,
I ride a 2000 VMAX 700 Deluxe and know very little about sleds.
I took the machine to the dealer for som TLC ( New track, carb cleaning, and a once over ). Carbs were precautionary, track needed replacing, and I wanted to see if cleaning the carbs would fix the bog that I get off the start.
Clutches are all stock and so are the jets.
Tech suggested I could go 1 jet size smaller and that might help ..... but I don't want to mess with the thing as it has never burnt down, been very reliable and the carbs were pretty clean -- even though it had been about 4 seasons since cleaned last. Other than that everything is supposed to be in A1 shape. But the bog is still there.
He did point something out to me --- that the choke springs are typically very weak on these machines and sometimes the choke does not close all the way. Suggested that I open the lid and close with my fingers
Does anyone think it a bad idea to put some stiffer springs in there ( I was thinking that I would take the armour spring off an automotive brake line and cut those to size and see if that helps). Would this be a waste of time ?
Thanks in Advance,
Scott
Thanks in Advance,
Scott
