oil injection - bypass
chilli
North Bay, ONTARIO, CANADA
I am trying to rule out some issues, and wondering if I disconnect the cable for the oil pump from the throttle, does that do it?
How do you bypass all together (with oil in reservoir). I dont want to remove the oil as this is just trial/error with premix vs injection
It should go to full rich with cable unhooked....just clamp the oil line closed going to the pump if temporary.....not sure why on earth you would want to try ...but you could.
I dont see what the diffrence is between mixing inside the pump vs mixing inside the tank
I am trying this to rule out the oil injection for my ongoing fouling issues, ands it seems the are fouling very black - aka too much oil
So, im going to run a tank full with premixed oil and gas to see if the fouling goes away..
There may be an issue with sharp right turns, pulling the oil cable too much.....
