2001 SXR skid swap
Kalamazoo, MI
Does anyone know if a RX-1 skid will bolt directly into a 2001 SXR? I have a 2003 or 4 skid from an RX-1 and I would like to put it into my SXR. I have been searching this site for the last several days and believe it will work, however in some SRX posts there has been references to a different length crossshaft on the SRX vs. the RX-1. As mentioned above I have a SXR.
Thoughts??
as far as i know it should bolt right in. what is wrong with the sxr skid? might just be easyer to steal some parts from the rx1 skid to fix it up.
The SXR skid is not really all that bad. I just happen to have a 0 mile RX1 skid available and the SXR has 5800 miles on it. I figured the shocks/bearings have seen better days and I need to replace the hyfax anyway. I am in the process of fixing the speedo pin/bearing this weekend and might just slip the Rx1 skid in to gain more travel & upgrade.
I just want to make sure that I am not creating a nightmare by doing this. If it is a direct bolt in, I'll probably just do it.
