i got a 97 vmax xt 600 twin, i just put new rollers in it and stock weights with a new belt. it has no power what so ever out of the hole almost like i have to push it to get it to go. but if iam rolling along at 20-30 mph i got all the power i could ever ask for and at top range all the power i could ask for. i cleaned the crabs, and it still didn't slove the problem. what should i do now or does anyone know whats wrong with it. pm me if you wnat
mopar1rules
did the primary spring break?
make sure your e-brake is off.Maybe your clutch is binding..need new bushings also.
I have even driven with a broken primary spring and sled still moved.
Rpm,s should be about 75-7600 rpm when u wack the throttle & climb to 7800 rpm.
spring is good and bushings are all good e brake is completely off, works great on top end it is not turning over 8 grand just got nothing at all on low end
did you put the right rivets in the weights?
yeah they are stock weights
Yes, but they come empty
you need to add a 3.6gram and a 4.5gram rivet to them.
and you need to put them in the right holes
Is it possible that you put the wrong belt on it?
