Will a 2003 rx1 rear suspension bolt up easy under a 98 SRX?
Yamidude59
Eff no. Serious modding.
WNYViper
Whats different about the 03 RX1 skid? I thought it was a Proaction like the rest. (Here comes the education, lol)
disreguard the obove post.
you can bolt it right in. the only thing that is needed is this. remove your upper rear shaft and install it in the rx1 skid. they have a shaft that is about 1in narrower. then it will bolt right in.
you will have to adjust the front end and rear skid for the new angles. you may want to atleast do a front bracket flip for the front shocks to lift the front of the sled.
read the threads in the FAQ tech section on setup and alignment for help with it.
good luck.
good luck.
Yamidude59
learnin somethin new every day!
