stretchSXV
Had the kids riding today in the yard and my son tells me the viper is making a weird noise. I get on it and it sounds like something is rattling around in the skid. I stop and look under. Didn't find anything. I went to get my uncle and when we came back we found a spot of oil about 2-1/2" back from where the can comes out. I got it in the garage thawing out. Any idea's what I should look for?
9801srx
probably lower chain case brg and seal .
stretchSXV
VenomMod
stretchSXV said:What's BRG?
bearing
x2....9801srx said:probably lower chain case brg and seal .
stretchSXV
Well at least now I have something to work on next weekend. Was planning on going to the yami demos but this comes first
let us know what ya find...
Dave M
Easy fix...Check the tech section..but just need to pull the chaincase, replace bearing and seal... reinstall chaincase... should only take about 1 hour, and you can still make the demo rides. May want to check the jackshaft and speedo side bearings too.
stretchSXV
Sweet Dave M. One hour would work. I'm going to try and do it Friday after work. I'll take pics as I go.
stretchSXV
How do you get the chain case off from the brake caliper. Found out my tension bolt completeley worked its way out and the tensioner broke some of the chain and put a hole in the inner case. How do I get the case off?
stretchSXV
What a fun time. I called 3 local yamaha dealers today and none of them had the chain, gasket or bearing.
stretchSXV
Dave M
Looks repairable....now to just get the parts quickly.
stretchSXV
Dave M said:Looks repairable....now to just get the parts quickly.
Took a friend no time to weld it up. So now I gotta get parts either from this website or order them locally.
