Just wondering what the stock length is for a 04 viper s
stock setting anyone
Yamidude59
Set it at 15mm thread length on top and you should be good to go.
Sorry, just looked in my manual and no dice!! It has all the shock adjustments,fra adjustments, track,control rod, etc.,etc.. But no limiter strap adjustment!
nothinbutansrx
I would start with the straps just snug with no weight on the sled and adjust from there after riding.
what are you trying to achieve?
I want the sled to handle good on the trail and in the deep stuff.The straps are loosened right off now and I don't know where they are suppose to be.
nothinbutansrx
For groomed trails you will probably be around snug w/no weight on the sled, if it still pushes go a little tighter. For deep powder you won't want that much ski pressure so let up on the straps some (loosen).
